Turd Furguson
it's a funny name.
- Jan 27, 2020
- 64
Hi All,
An interesting link was posted here regarding SOC voltages and recommended Bulk/Absorb/Float levels for LifePo4.
I am designing a 12v, 300ah house bank for a marine system around 8x150ah cells from BLS and two of the recently recommended BMS’ from BatteryHookup. My preference is to maintain a SOC of 80-90% and only top- up the batteries to 100% whenever needed for extended periods off-grid. This capacity is overkill for everyday use & day-trips as AC shore power is available, so I can leverage the opportunity to extend cycle the life of my investment.
I currently have the charger pictured below that has adjustable Absorption/Float settings for different battery types and temperature conditions. (Statpower/Xantrex Truecharge 20+). Bulk does not appear to be adjustable with the manual stating that it delivers 20amps until the gassing voltage is achieved - "typically around 14.4v with approx 75% SOC restored". Float mode can be disabled entirely.
My question is whether you think I can adjust my SOC by flipping the switches between the absorption/float options to adjust bank capacity as needed? My theory is to maintain a lower SOC at 13.x-14.0 volts, then flip the absorption to 14.4-14.6v before a weekend away.
Alternatively, could achieve the same outcome by adjusting cutoff voltage within the BMS? This option seems plausible but likely poor practice, especially with multiple BMS units.
Thanks!
Thanks!
