Rlsimon
Lithium guidance
I have read all my brain can absorb and still have a couple of questions. I have a 48v Club Car DS that I use for hunting with the common upgrades(controller, motor, reverse switch, wires, etc). The Trojans are done so it’s time to make the switch. I have a bunch of LEV60F 74ah cells. If I can get away with a 16S pack I will but I’ll probably end up with 16S2P with two BMS.
Questions
Questions
- Could two JK B2A20S20P (200 amps continuous,350 peak) handle the power without a separate hv/lv cutoff?
- If no to #1, what is the most simple, dependable solution? Build it with relays and diodes, gigavac contactor, etc. I read that a MJZ400 solenoid could be used but not how.
- How would I wire the two bms together for the hv/lv cutoffs to work together?
