That is indeed the exact same thermostat that I had, that I no longer use.
I got even more clever, the switch that turns the heaters on has 2 leds, one is internally connected to light up when the switch is on, the other has another terminal that I connected to the output of the thermostat. So when the switch is on its lite to let me know its on, the other led lights when the thermostat is closing the contact, so I have a visual that the heaters are on. I can also peak at the thermostat for the current temp.t works pretty great and I can use the victron bluetooth app to see the current battery temp and when the relay is closed / heating and open/off. .
mine are stuck on the short side of the stack. 2 per battery and that seems to be fine. each cell gets an even amount of heat as the others.If they were extremely low power, would it be okay to stick the silicone pads directly on the batteries? I'm using two 100AH Renogy batteries and I have ordered a handful of 1 amp 12v pads (one on each side of each 100AH battery, 8 total) that I plan to run at 5v (or 9v in very extreme cold). Not very much heat but I was planning to go heavy on the insulation and I'm looking for a very slow constant heat. At 5v or 9v it's pulling a little less than .2 amps and .5amps respectively.
What’s the lowest ambient temperature been so far and how long does it take to cool back down to 34?UPDATE: After several days of testing I have come to the conclusion that the temperature spread on the heating pads does not need to be so large.
I have two battleborn heat pads surrounding (3) 100AH Battleborn batteries. Each heat pad has two elements, so four heating elements total. The power draw on all four is approximately 3.6amps. The thermostat sensor is taped to the top of one of the outside batteries. When the thermostat triggers it takes about 90 minutes to heat the batteries from 34 to 44 degrees "F". After the thermostat trips off at 44 degrees the battery temp gardually climbs another 5 degrees. I have decided to change the settings on the thermostat from 34-44 to 34-38 degrees "F". This I hope will keep the batteries above freezing and below 44 degrees.
The new settings are working out great, 34-38 on the thermostat produces 34 to 41 actual on the batteries.
The thermostat shuts off at 38, but the temp rises some after it trips.
I adjusted the P2 setting to -1 so the thermostat reading would match the temp on my Victron monitor.
I really like this thermostat.
So I think the lack of an actually flat surface on the sides of my batteries is slowing down the heat transfer. I was going to fill the gaps with rtv silicone sealant but then quickly realized that is thermally insulative, not conductive and that may have the opposite effect I am looking for. Any ideas for an alternative sealant/glue? Ordered a few aluminum sheets to spread the heat out a little more but I feel like it will still have an issue penetrating the battery.If they were extremely low power, would it be okay to stick the silicone pads directly on the batteries? I'm using two 100AH Renogy batteries and I have ordered a handful of 1 amp 12v pads (one on each side of each 100AH battery, 8 total) that I plan to run at 5v (or 9v in very extreme cold). Not very much heat but I was planning to go heavy on the insulation and I'm looking for a very slow constant heat. At 5v or 9v it's pulling a little less than .2 amps and .5amps respectively.
I found a lot over the last week, even some modified silicone adhesive like regular rtv that was really good, but like $70-100+ for a small tube. Cheapest seemed to be $45 on amazon for some MG chemicals stuff. I was just hoping there would be something that was somewhere between thermal insulating like regular RTV and thermally conductive like regular thermal epoxy/paste/etc and not 10 times the cost.Thermally conductive epoxy
It’s still $15 for a super super tiny tube like many other computer paste options. The sides of my renogy batteries are terribly not flat and filling in all those pockets would take a lot.You might be interested by:
