technerd1988
- Mar 25, 2021
- 13
Then what is the thermostat for? How did you get it to come on only during charging? Did you use the canbus on it? same thing I have. If it don't get below 0C for charging or -20C for discharge in there you dont need to worry about heaters I think. The problem with using heaters is that you are cycling that pack and slowly degrading it as your not using it. just such a dumb waste idea to me unless your standed in a tent in the freezing cold and you need to radio in help or something. The other problem with over insulating the packs is that your not allowing heat to escape either
