Ozark Tinkering
- Dec 23, 2021
- 1,105
Those do look nice, but for most of us using 120VAC would require firing up the inverter, which would be counterproductive. My little 12V 12W heating pads fit my needs better.Coming from a gardening perspective of keeping delicate seedlings at just the right temp makes all the difference. These mats are cheap, durable and come in all sizes. This size only consumes 17.5 watts. If you have 120vac close by this might be an option?
I sure don't disagree since I haven't taken a survey, but in my case, as in the case of anyone coming from a grid connected world, there has always been a 120vac outlet in my shop close to where my DIY back-up system will be set up so it's just a no brainer in my case. I already own these and most of the time they just lay in a drawer unused. My batteries will remain snug and warm, plus that way they can also serve double duty when gardening time arrives. I'm just trying to keep it in the true spirit of DIY?Those do look nice, but for most of us using 120VAC would require firing up the inverter, which would be counterproductive. My little 12V 12W heating pads fit my needs better.
My situation and use is similar. I had a seed starter heating pad and figured, why not.I sure don't disagree since I haven't taken a survey, but in my case, as in the case of anyone coming from a grid connected world, there has always been a 120vac outlet in my shop close to where my DIY back-up system will be set up so it's just a no brainer in my case. I already own these and most of the time they just lay in a drawer unused. My batteries will remain snug and warm, plus that way they can also serve double duty when gardening time arrives. I'm just trying to keep it in the true spirit of DIY?![]()
Well, well...maybe I should take a survey?My situation and use is similar. I had a seed starter heating pad and figured, why not.
Yeah, I bet it would basically come down to "on-grid / backup" vs "off-grid / mobile". When you say you already have a 120V plug near your LFP battery, to us off-gridders it makes our heads hurt!Well, well...maybe I should take a survey?![]()
Take 2 aspirin and call Will in the morning.Yeah, I bet it would basically come down to "on-grid / backup" vs "off-grid / mobile". When you say you already have a 120V plug near your LFP battery, to us off-gridders it makes our heads hurt!![]()
I'm using those same 7W polyimide heaters stuck the bottom of an .060 aluminum plate. In free air, I can't get the plate much above 100 degrees. With the cells on top of it, it doesn't get more than a few degrees above cell temp as the cells are conducting the heat away as is intended.Yeah, you need to use a heat spreader (aluminium block or something) with those.
Consider having the thermostat heaters come on a few degrees before the BMS cuts charging.The thermostat is set up so that heating starts at 5 degrees Celsius (41 F) and stop at 10 C (50 F).
On top of that, I have two BMS controlled 15 W pads in each pack that only heat when a charge is present (the BMS cuts charging under 5 C and powers the pads until the sensors reach 10 C).
Or maybe more than a few degrees. It won't cost you much in terms of energy to do the heat, and it avoids the issue.Consider having the thermostat heaters come on a few degrees before the BMS cuts charging.
Do you know how many Ah were used by the heating system for your overnight test? Is your long term plan to add insulation?For those trying to heat smaller cell packs, here's a heating pad test we did on a 4s 200ah pack (8.5" x 8" x 6.75") that some may find useful.
We applied a pair of 3x4" 12v 25w (6 ohm) silicone heating pads directly to the cells, on both, long sides of the pack (total 4 pads). Wired them series, parallel which dropped the total current for all 4 pads to 2.2a (26w) at 13.6v. With all 4 pads wired in parallel, they got too hot to comfortably hold, approx. 160f, and drew almost 9a of current. Two pads in series, approx. 120f (1.1a).
Used a power supply to power the pads for this test. As for future plans, haven't decided whether to power the pads via the heating port on a JBD 200a BMS or use a separate thermostat.
Temp sensor for the cells was located on the top, center area of the pack, in between the 2nd and 3rd cell.
Placed the cell pack (with the 4 heating pads active) inside a generic, plastic Group 24 marine-type battery box (with a top attached) and *no* insulation, outside around 10pm. Outside temps 8f. Cell temps 64f. 8 hours later, outside temps had dropped to (zero) 0f. Cell temps had only dropped 2 degrees to 62f. An IR gun confirmed cell temps on all four sides and top.
Wanted to confirm these 4 pads would heat the cells low and slow using minimal current, and give us the capability to safely charge the cells in sub-zero (<0f) temps. For us, this test was a pass on both counts.
I believe 2.2a for 8 hours would equate to 17.6ah.Do you know how many Ah were used by the heating system for your overnight test? Is your long term plan to add insulation?
PIR is fire resistant. It will chare and carbonize, but it will not sustain a flame. The more traditional Rigid polyurethane (PUR) is far more problematic in a fire situation.
A 2011 study of fire toxicity of insulating materials at the University of Central Lancashire's Centre for Fire and Hazard Science studied PIR and other commonly used materials under more realistic and wide-ranging conditions representative of a wider range of fire hazard, observing that most fire deaths resulted from toxic product inhalation. The study evaluated the degree to which toxic products were released, looking at toxicity, time-release profiles, and lethality of doses released, in a range of flaming, non-flaming, and poorly ventilated fires, and concluded that PIR generally released a considerably higher level of toxic products than the other insulating materials studied (PIR > PUR > EPS > PHF; glass and stone wools also studied).[10] In particular, hydrogen cyanide is recognised as a significant contributor to the fire toxicity of PIR (and PUR) foams.[11]
The danger is that they don't end up with a flat surface to mate with the cell pads (or whatever they are being bolted to) If you put the part that needs to be flat in the jaws of a vice you can keep it flat while bending the part that hangs out. (If the vice has serrated jaws, put a piece of flat metal between the jaw and lug so the serrations don't imprint on the lug)One thing I need to do is either make or buy some angled 2GA battery lugs. Do folks see any issue with bending straight one to make them work versus buying angled ones? I have a stash of straight one and would prefer not adding to the collection
Makes sense and by cell pads, I am guessing you mean the battery posts? Right now my battery is upright and I use flat lugs, but with the battery on its side in a to be built box, I need angled ones.The danger is that they don't end up with a flat surface to mate with the cell pads (or whatever they are being bolted to) If you put the part that needs to be flat in the jaws of a vice you can keep it flat while bending the part that hangs out. (If the vice has serrated jaws, put a piece of flat metal between the jaw and lug so the serrations don't imprint on the lug)
yesI am guessing you mean the battery posts?
There are bending radius specs to follow when bending higher strength aluminum allows like 6061-T6.Some metals don't bend well. I tried bending 1/8" T6061 into a right angle and it broke. Hopefully copper works better for you.
Aluminum Minimum Bend Radii | Cumberland Diversified Metals
CDM buys and sells aluminum coil, strip, sheet and plate but also trades tube, bar and structural products.www.cumberlandmetals.com
