You can find lots of threads here of people using different types of heating pads, mostly separated from the cells by some metal sheet, but I think some have actually taped the pads directly to the cells (I would not recommend that).Since we don't need a lot of heat produced inside an insulated box, how about using using a few 30 watts resistors to produce heat inside the enclosure? I can lookup an adjustable thermostat and we could size R according to your battery voltage so it barely keeps it above freezing?
Is heater #1 the 4.5A load? What current do the other two pull?I have a new system in Alaska. -15 -20 Fahrenheit last week (-40 on a rare occasion some years). Cabin has no heat when unoccupied. LIFEPO4 12V system. I built an insulated battery box and put a 60W forced air fan PTC heater in it. This heater is designed to be in enclosed distribution boxes. Inside the cabin today is -3.5 deg. The heater comes on for 4 min every half hour (about 4.5 amps). I use a thermal snapdisc (40-60) inline with the positive input wire as a thermostat. Temperature is stable at 50 deg +- 5 deg F.
I currently have 3 heaters hooked up and have a manual selector switch to activate each one individually.
1. PTC heater
2. Car seat warmers placed on the underside of an aluminum plate and batteries sit on top of plate.
3. Two small plain PTC heater elements with no fan secured to a small metal plate just laying there on top of the aluminum floor of the box.
Snapdisc are still used for control.
It boils down to Low, Med and High. given current flow and time on, They all come out to about the same amps drawn. It just how fast do you want it done.
Read up on the PTC heaters.
and
https://dbkusa.com/blogs/whatisptc/ptc-heater-types-explained
The two PTC heaters (connected in parallel) that lay between the batteries on top of the aluminum plate spike to about 4 amps on start up for several seconds and then are on for 35-40 min at 1 amp.Is heater #1 the 4.5A load? What current do the other two pull?
I'm having a little trouble visualizing this. I get that #2 is under the aluminum plate. #3 is "on top of the aluminum floor of the box". Is this under the #2 heaters?
I would think that moving air around is not the most efficient way to keep the cells warm. I would think the heater under the batteries (with an aluminum plate to spread the heat) is your best bang for the buck. It seems like a PTC heater mounted under the aluminum plate would be best, if you can get PTC heaters without their own spreaders.
How much insulation do you have?
Sounds like you have a solution you are happy with.The two PTC heaters (connected in parallel) that lay between the batteries on top of the aluminum plate spike to about 4 amps on start up for several seconds and then are on for 35-40 min at 1 amp.
The heating pad (different than the seat warmer mentioned in the previous post) under the aluminum plate is pretty steady at about 2.5 amps for 25 min. (30 W heater)
Heating the air is exactly what I want. Every part of the battery is subject to the heated air. Constant surrounding temperature. I have no desire to heat just the bottom of the battery. All three of these methods are heating the air. Even the pad underneath. The batteries sit on top of a small neoprene pad (1/4"). A consistent 45 to 50 deg will keep the entire battery well out of the danger zone.
Next week I hope to move to Two 200AH LIFEPO4 batteries instead of Two 100AH.
The box insulation is 2" R-10 XPS foam. All sides. The box has plenty of room for the air to move around. The batteries are not crammed in there.
Interior dimensions are roughly 22"L X 14"W X 12"H. The Aluminum plate sits off the foam with a 1" air gap to aloww room for the heating pad and wires.
The car seat warmer mentioned in the previous post is pretty neat in the sense that it has its own High and Low switch. (70W & 25W).
Its all going to come out roughly the same. It take's X amount of current to heat X amount of degrees. Placement of the snapdisc thermostat is also a key factor.
If you heat the air space around the batteries they never get cold soaked. I heat the air around mine and they stayed at 45-50 degrees in single digit temps in a plywood enclosure with little to no insulation. Plus I can cool them in the summer when pulling high C rates if needed. It is a lot easier to keep a battery warm by using its thermal mass to your benefit, I looked at heating the batteries directly but the heat pads were too hot for me to be comfortable even spreading the heat with aluminum sheet.Sounds like you have a solution you are happy with.
Just be aware of the physics that are at play here. The LiFePO4 cells are by far the majority of the thermal mass in your battery box. Probably over 90%. Heat them, and the rest will stay warm. Heating the air around something is just about the worst way to warm that something, especially if it is the main thermal mass.
2" XPS is good. That is what I used in my heated / insulated box. I have 8 230Ah Eve cells, and I have 2 x 12V,12W silicone heating pads. The pads are under an aluminum plate, which is under the cells. I'm currently testing it with an outside temp that hasn't got above 25°F for 24 hours. It has used 4Ah to keep the pack between 50°F and 60°F. The next 36 hours will be a tougher test, as the temps are to stay mostly below 20°F, and between 5°F and -5°F tomorrow night.
I am using a 25 watt silicone pad on each battery , I never checked the temp except by touch. I felt like it would put too much heat directly on the batteries.Even those small 7W Polyimide pads, like these? (if you tried them). I've had very good results with those.
I used some silicone pads rated 12v and 15 watts. Put pairs in series for 1/4 the wattage. Sorta felt warm in my hand. Stuck one to each cell without worry.I looked at heating the batteries directly but the heat pads were too hot for me to be comfortable even spreading the heat with aluminum sheet.
As long as you can limit the heat to a low enough level I don’t see a problem doing it that way, I needed a way to cool the batteries in the summer.I used some silicone pads rated 12v and 15 watts. Put pairs in series for 1/4 the wattage. Sorta felt warm in my hand. Stuck one to each cell without worry.
Those are the silicone heating pads, which at least limit to a max heat of 60°C. I found that the polyimide pads that @upnorthandpersonal pointed to (I bought those exact ones) heat up too hot too fast. The biggest risk to watch out for is heating one area of the cell (where the pad is attached) to a relatively high temperature before the other side has even gotten warm. That could damage the cell.I used some silicone pads rated 12v and 15 watts. Put pairs in series for 1/4 the wattage. Sorta felt warm in my hand. Stuck one to each cell without worry.
I am using the silicone @140 degrees, I still think it is too hot for direct contact.Those are the silicone heating pads, which at least limit to a max heat of 60°C. I found that the polyimide pads that @upnorthandpersonal pointed to (I bought those exact ones) heat up too hot too fast. The biggest risk to watch out for is heating one area of the cell (where the pad is attached) to a relatively high temperature before the other side has even gotten warm. That could damage the cell.
By your putting the silicone ones in series you should be limiting the heat pretty well. I would feel better if you were using a heat spreader like an aluminum plate, but maybe it isn't needed. I assume you only have them on one side of the cells, and not the other?
