LiFePO4 internal resistance question
Phil Orton
I have 4 cells: The IR readings using the 5 in 1 cell meter that Will used in one of his videos are: 010,002,002,007. My question is: Based on these readings are these 'normal' or are there any areas of concern that I need to watch? Did some research but could not find information or I just didn't understand it. LOL.
toothy
Good question, I signed up a few day ago to ask the same exact one, but with different numbers. I did find that taking repeated readings with an imax balance charger gave very different readings. I was going to do a reading with the Fluke and resister and some math but I think I need a way bigger resister to get usable results on a 400Ah cell. My 16 cells call for under or equal to 0.40mOhm and they are all 0.22 to 0.30 but like I say the measurements were jumping around. Take 4 readings one after another and some would be way different with no pattern.
Phil Orton
My readings change some also. Interestingly the cells at 002 stay the same and the other 2 cells vary somewhat, however, not much.
MisterSandals
Participation Medalist
I just got my Tenergy 5 in 1 today so tested the IR on my 3 banks, 206AH LiFePO4. I got similar readings as Phil on all 3 of my new banks (4s). This is pretty suspicious that ALL 8 of the readings (Phils and mine) on the middle cells are 2!!?
Bank1: 10 - 2 - 2 -10 (first and last cells vary from 9-12 on different tests)
Bank2: 10 - 2 - 2 - 4 (last cell ended up as 5 on the last couple tests)
Bank3: 7 - 2 - 2 - 5 (consistent readings)
I am going to separate one of the banks and do tests on individual cells.
Anybody else with a Tenergy have some IR numbers?
MisterSandals
I ran quite a few more tests with cells in different 2s, 3s and 4s combinations.
Summary: 90% random, 10% dependent on location in series (first cell highest).
I used the 4 cells in Bank3 above in a few different 2s, 3s and 4s combinations. The Tenergy 5 in1unit does not handle 1s (i knew i should have sprung for the 6 in1 !!!)
Check out row 8 and 9 with cells 9+12 and cells 12+9 (different order). Random!
Anybody see a pattern other than first cell in series always highest?
Cell #'s4s (ohms)3s (ohms)2s (ohms)
1+2+3+410-2-2-10
5+6+7+810-2-2-4
9+10+11+127-2-2-5
10+11+1212-2-4
9+1010-4
10+118-5
11+128-5
9+1211-4
12+910-3
10+11+12+98-2-3-5
Summary
97,510,11,3
102,8124,8
112,225,8
125,345,4,10
