LifePo4 not charging well.
Range
One of 4 of my batteries does not charge beyond 3.37v while d next to it is about 3.45v the last 2 are over charged to about 3.6 n 3.7 respectively. Overall charge on meter is 14.2v full charge. I make use of heltec bms. However, during usage/discharge,each battery reads same voltage for all 4 i.e about 3.31v or there about.How do I fix this pls? Battery is lishen 105amp, 3.2v.
Did you do a proper top balance?
It seems your cells are not on the same SoC.
On a long run Heltec can bring all closer, but nothing is better than top balance
It was top balanced when a friend delivered it to me and everything seems fine. It all started when a terminal of one battery worned out so there was no firm grip.Now, d terminal is fully fixed now and grip if super.
That seems to be a bad connection on the terminal. Did no good to the cell but if cell not bloated then OK
Try the top balance first :)
+1.
Disassemble, connect in parallel, apply bench power supply at 3.5v until current drops to zero.
Reassemble in series
Problem fixed.
I dont have a bench charger. A big culprit.
I only v 12v charger.
When you battery is charging and the cell voltages of the high cell starts to increase above the other cells, apply a load across the cell for several seconds, use a 12v car headlamp bulb, whilst measuring the cell volts. Repeat with the high cell as necessary.
Alternatively accept you are loosing a small % of capacity and charge to 13.8 or 14 volts.
Mike
+1 ^^^This^^^
And, your Heltec hopefully will get things more balanced at the high end of charge. Then, should you find you need the last 1% of capacity, you can charge higher.
Mike
Thanks Mike
But the discharge will decrease all cells.
Really wish I have a 3v device
You are using the current flow through the resistance of the bulb to dissipate energy from the selected cell and lower its capacity slightly. Could could use any suitable resistor.
A headlight bulb is readily obtainable and the fact it ' lights up' ( even on 3 volts) is a useful indication you have made contact.
With a little practice you can judge how long you need to make contact for the necessary volt drop. It needs only seconds, typically 1 to 10 seconds of contact to make a measurable difference.
It sounds a somewhat crazy idea, but it does work.
Mike
Is it same as connecting to an inverter and discharge with loads?
Not really. With the bulb, you are targeting an individual cell to do a makeshift balance. Using the inverter as a load will load down all cells at the same rate (more or less).
I know I am coming in late, but it looks like there wasn't enough attention paid to making sure the terminals, lugs, and bus bars are good and clean. Based on what you've said, it does look like you need a top balance, but I would bet money that you also need to properly clean the terminals, lugs, and bus bars with fine grit sandpaper and isopropyl alcohol. also apply some oxguard or noalox during reassembly.
Reactions: Mia
Mike
Wow!!!
Will try it out and get back to you.
Bus bars, terminals, lugs are still fesh. Will check if discharging the high cells fail.
Aluminum terminals will immediately begin to accumulate a layer of oxidation. If you didnt scuff them before assembly, then you need to. and since you're taking them apart, you'll likely need to do the same to the lugs. At the very least clean them and the bus bar(s) with isopropyl.
Reactions: Mia
Ok thanks a lot
Thanks to everyone who replied.
