Hawkgoalie31
Hello,
I have a stock Jayco Feather 2024 stock Solar system with a Go Power 30aamp solar controller. When I replaced the stock lead acid battery’s with the LiFePO4 200ah battery it’s not charging the battery. Everytime I check on it it’s like the battery is asleep and the system try’s to wake it up. I switched the controller to lithium battery still no luck. The controller gives me the error code 32 LUE which means it’s not detecting a battery. I am wondering if anyone else has had this problem and what the fix should be.
