Voltage is a huge factor here. The higher the voltage, the higher the chance of unintentional arc'ing. So while the fuse might be fine to interrupt 10kA at 12v, it might not be at 48v (not to mention you'll have more amperage on a short circuit of an LFP bank at 48 than at 12). And while this guy's test proved OK, it might not be OK 100% of the time. You don't want to be the 1% guy whose fuse fails to function properly and burns your house/RV/boat down. Personally I would never use MRBF as a main fuse for LFP, especially in a 48v configuration.
And as others have noted, the rig itself can be a factor -- it depends on the size of the wire exiting the fuse holder (and the wire involved in the rest of the short circuit). Personally, I'm going to assume a very large crescent wrench is providing the short circuit
I moved to a DC 250 amp circuit breaker because I blew two 300 amp class t's (80 bux) with inverter inrush current. The breaker was ~$90 and is rated 50kA. And now I also have a nice battery switch.
