I'm currently using AGM batteries and according to all available information they are not good for constant cycling. So using these batteries every day during night hours means that with 50% discharge and 300-400 cycles they will be dead in a year. So I'm looking into replacing them with 2 150ah LiFePO4. This will allow to power the house during non-solar hours for much longer then with AGM and down to 0.25-0.3C But I'm little paranoid about fire. Yes, LiFePO4 are much safer then LI ( or so they say), but still.
Question - is it possible to store LiFePO4 batteries in ground? My whole solar station is outside. I'm thinking about digging a whole ( hydro isolated) and putting batteries in standard plastic battery boxes in there. And covering it all with a plastic box with say 3-4 inches of sand. So in case of Lithium fire plastic will melt and sand will cover the fire. Or lining the hole with fire bricks and covering with concrete lid? Maybe installing a 1/2" breathing tube ( are there any gases from LiFePO4?). Temperature in the ground should be more or less constant or at least not extreme. And in California do not have to warry about freezing. Any thoughts? Thank you
