Very new to the topic.
I was hoping someone could
a) tell me if I am thinking correctly
b) draw a general diagram and components of how to put together a system.
Here is the rest of the story
I have been putting sweat, blood and tears into my somewhat aging but great sailboat. Just replaced an engine and fixing many things that aged over time.
I currently use 2 Lifeline 105AH Deep Cycle batteries with A/B Switch. This is how I bought the boat 25 years ago.
I added Xantrex Prosine 2.0 many after purchase.
In the summer live and work on the boat for weeks at a time. And I am doing a bit more cruising now. As a result want to upgrade batteries and charging systems. In stages however.
My needs are laptop (via inverter) and second monitor (12v DC), fridge and microwave occasionally when my family is on the boat.
First stage batteries - and may be a small removable solar panel to top off batteries when not using the boat.
Second stage - permanent solar panel - although that is not immediate. I have too many other projects to accomplish first.
I learned that I cannot connect alternator from the engine to Lithium for a fear that if BMS cuts off the alternator will burn out.
I was hoping to replace 1 Lifeline with 300AH lithium and keep the other AGM in place. That ought to handle all my current needs (I am used to living with less)
So the charging would be from the engine/shore power when available and from the solar panel as a backup. I understand that Prosine charger cannot charge Lithium battery so I would need a second charger. And here is where I pause for lack of knowledge and understanding and ask for guidance from the forum.
Thank you
Gene
Thank you
Gene
