FilterGuy
Solar Engineering Consultant - EG4 and Consumers
Hi folks,
I have a particular interest in LiFePO4 batteries that can survive cold environments. This includes both cold temperature charging and cold temperature storage.
Most of the batteries discussed on this forum tend to have a charge temp limit around 0c and storage temp seems to vary wildly. However, some batteries are designed for lower temps. I thought it might be good to start a thread about these batteries to share knowledge and experience.
The low-temp batteries I am aware of are:
I am curious what experience others have had with LiFeYPO.
- Valence https://lithiumwerks.com/valence-batteries/
- Dakota Power https://dakotalithium.com
- Grepow: https://www.grepow.com/page/low-temperature-battery.html
- Thundersky-Winston: http://en.winston-battery.com/index.php/products/power-battery/item/wb-lyp100aha?category_id=182
- Have you found other low-temp batteries?
- Besides the low temp, is there other attributes of the LiFeYPO that is different than 'normal' LiFePO?
- Have you run into problems with any of these batteries?
- Have you had any problems with the company?
From other threads, I have heard that Valence ignores you if you don't buy from them and that Dakota Power has a delivery problem.
