Lights
wyattamdahl
California
I have 8 led lights 6 watts each, in parallel, these are connected to a three way switch, and the. To a dimmer. The rimmer works, but only one three way switch is working. When turned off, they stay on partially. Any idea where i went wrong?
LeisureLED 5 Pack RV Boat Recessed Ceiling Light 480 Lumen Super Slim LED Panel Light DC 12V 4.75" 6W Full Aluminum Downlights, (Neutral/Natural White) https://www.amazon.com/dp/B077Y78SV4/ref=cm_sw_r_cp_api_i_DHEJFb9B303AK
ALOVECO 12 Volt DC Dimmer Switch... https://www.amazon.com/dp/B07Y2XC225?ref=ppx_pop_mob_ap_share
Please post a schematic of how you have things wired (check your actual wiring to make sure the diagram matches).
Check the wiring of your two switches.
Is there a charger involved here? If there is, unplug it from it's power source, the grid/mains probably. You might be seeing leakage current keeping the LEDs lit. It takes very little power to make a LED glow dimly.
It shouldn't. If the dual switches are wired correctly they should break the - feed to the dimmer so no DC should be available to it. That leaves leakage current as being the only way to light the LEDs. You can check to see if there is leakage if you take the dimmer out of the equation so that only the dual switches remain. When you turn the system off with either of the switches do the LEDs remain dimly lit?
AC wiring running next to the DC wiring could couple enough current into the DC wiring to cause the LEDs to light.
Have you checked the wiring of the two switches as per that tutorial?
