conquistador
- Sep 21, 2021
- 108
Today I checked my little system and found battery electrolyte leaking. One LiitoKala cell which was already damaged when I received it, was leaking.
This is a potential fire hazard, as the cell might lose all electrolyte and become hot while still charging. Thermal runway, and fire could result.
In the picture "cells-1july" you can see that cell1 was charging much faster than all other cells and discharging much faster too. My charging was always below 10A and usage never more than 6-7A.
This post is to warn all buyers not to be naive like me when buying on Aliexpress. I bought from 2 different shops with LiitoKala in the name and both times I received bloated G-grade (garbage) cells. If you have not the money to buy good cells, stay with your Lead-Acid or save until you can buy from trustworthy sellers. For a few hundred $ € ...difference, you do not want to risk fire, not even outside of your house.
I have now also disconnected my other LiitoKala battery, because it's just too risky to run g-grade cells.
