thegoogler
- Apr 15, 2021
- 108
There's a very small dent in one edge. I don't think it will affect the cell performance or longevity. It is apparent that it was dented before being packed, given the packing material used.my mistake, I thought your pictures display dented cells, inspect them, if you are happy and move on, if you did not get what you paid for, dispute with CC.
I'll see how these do once top-balanced and discharged but I suspect they aren't terribly well matched. All 4 arrived within 1mV of each other, but upon top-balancing in 12V series two of the cells hit 3.65V limit while the other two were more than 130mV less. I'm going to balance in parallel now that they're close. Resting state I'm seeing 3.558V, 3.554V, 3.441V, and 3.443V. I'm hoping these two low cells were just not quite as charged and will top out as expected once I balance in parallel now that they're close.
Honestly my two biggest complaints are:
- The cells are clearly rated at 271Ah by CATL. Even if they will produce 280Ah, it's deceptive. That said I totally expected these kind of shenanigans.
- Why are there 5 different sets of specs out there for CATL 271Ah batteries? Even the LiitoKala specs on the AliExpress site don't match. This bugs me since I want to be sure the set the right parameters in my BMS for charge/discharge temp cutoffs, but I've seen everywhere from 45 to 60C shown for both charge and discharge high points, and anywhere from 0 to -30C for low points (including some -5C and -20C specs for charging!)
