michael d
off-grid solar pilgrim
a report of 10 mA is how much on a 280 Ah battery? check my math, please?
280 Ah battery cell times 1000 mA per 1 amp = 280,000 mA
correct?
so 10 mA divided by 280,000 mA = what percent of the battery capacity?
10/280,000= 3.5.... to the neg 5th power x 100 = 3.5 to the neg 3rd power.
it will take 10 seconds to lose 1 milliamp.
60x60x24= second in 24 hours = 86400 second per day
86400 divided by 10 seconds equals 8640 milliamps per day
8640 milliamps divided by 1000 milliamps per amp = 8.64 amp loss per day(if you have that amount of leakage).
that would be significant if it was being drained off to something.
I think my 6 250 watt solar panels pushing 45 amps at over 28 volts will overcome that loss (if it is actually there).
my 2p8s 24-volt tops out most days but I will be increasing the battery bank size and the solar array significantly.
I think it best to insulate the aluminum cased prismatic cells between and under them with a non-conducting material.
then, you will keep the electrical inspectors happy, satisfy the NEC, and your battery build will be safer than with only the blue shrink wrap they arrive in.
One milliampere is equal to 1/1,000 of an ampere, which is the electrical current equal to the flow of one coulomb per second. The milliampere is a multiple of the ampere, which is the SI base unit for electric current. In the metric system, "milli" is the prefix for 10-3.
correct?
