LISUATELI 12V 100Ah Lifepo4 low temp protection
cgoetz1
I purchased a couple of Lisuateli lifep04 from amazon a few months ago. The batteries seem to be working well, but the description states that the BMS has low temp protection, but I am afraid that this is not true. I saw the batteries were charging on a cold morning around freezing and I had to disconnect my panels. Does anyone have any experience with this battery?
Many times when they say "Low Temp Protection".....It is not CHARGING protection, but they stop discharging at a low temperature.....
Thanks for the reply. I am a beginner, but I was under the impression that temps do not matter for discharge.
You are correct it is primarily for charging. Note that with batteries it can take a while for the temp inside the battery to drop, especially if in a compartment. Hard to tell if there is no low temp protection or if your batteries didn't hit the temperature needed to activate it
On another thread they are proving in real use that the battery does protect from low temperature charging.
How much they lasted?
