Sadie04074
- Dec 1, 2020
- 28
I found this battery company on Amazon. I asked them about their claimed low temperature charging protections because their Amazon blurb seemed not straight forward to me. I basically asked in 2 separate questions if it had BMS low temp protection at 0 C or if it has a built in heater. This is their response. Does it make any sense to those more knowledgeable than me?https://www.amazon.com/ask/questions/Tx1E77EFLXAVW6V/ref=ask_dp_dpmw_al_hza
Answer:
"Dear customer, thank you for your question. Our battery has a built-in BMS protection board to prevent the charging and discharging temperature from being too high or too low. Charging temperature detection temperature: 55°C, charging overheating protection hysteresis temperature: 50°C, discharging overheating detection temperature: 95°C, discharging overheating protection release hysteresis temperature: 80°C, charging low temperature detection temperature: -10°C, charging The release hysteresis temperature of low-temperature protection is -5°C, the release hysteresis temperature of low-temperature discharge detection is -30°C, and the release hysteresis temperature of discharge low-temperature protection is -25°C, because the low-temperature detection temperature of charging is -10°C. When the low temperature weather is 0 to -10°C, the battery will be charged with a small current when charging starts, and the battery will start slowly. After the battery is slowly heated, it will be charged with a normal current to ensure that the battery can avoid damage at low temperatures. Below -10°C, the BMS battery will stop charging to fully protect the battery. You can only charge the battery indoors to solve the use of special weather. The discharge limit temperature is -25°C. Thank you, below -25°C When the battery will stop discharging to protect the battery, thank you"
Answer:
