chrisski
Solar Boondocker
- Aug 14, 2020
- 5,186
I have ordered Eve 280 amp cells to make 24 volt batteries. I am planning on ordering one BMS for each 24 volt battery. I am looking at Overkill BMS 100 amps at 24 volts. I don't have either product yet, but am reviewing spec sheets for the build?
My question is, the Eves are supposed to be charged at 29.2 volts, but the overkill BMS has Battery Over Voltage at 29 volts. If I set my charge controller to 29.2, does the BMS stop charging when charging voltage reads 29?
This 29 volt limit seems to limit the batteries to .2 volts short of a full charge. Perhaps the charge curve for lithums is so flat that when it starts to spike, this is insignificant.
