EnergySolutions
- Jan 14, 2020
- 11
Full description:
Price: $195
Condition: New, never used
Manufacturer: SCUD
Enclosure and protection: Hard industrial plastic, scratch and impact resistant. Honeycomb cell holders and anti-vibration silicone between cells to reduce damage overtime. Water resistant silicone insulation. Metal screws holding together the cell holders and hard plastic shell)
Length : 9.87 inches ( 9 and 14/16 or 25.08 cm)
Height: 5.62 inches ( 5 and 10/16 or 14.28 cm)
Width: 2.81 inches ( 2 13/16 or 7.13 cm)
Weight: 8.7lbs
Voltage: 48v
Capacity: 19.2aH
BMS: 60a (Low Voltage/Overcharge/Temperature/Current output and Short Circuit protection, power equalization output)
Discharge rate: 60 amps continuous 90 peak (920w continuous or 1500w peak)
Max Charge rate: 2.5a
Limited Charging Voltage: 54.6V
Charging time: 5-6 hours
Cycle life: ~800-1200 full charge and discharge cycles
Configuration: 13 series 6 parallel
Cell type: lg-18650-mh1 3200mah
Amount of cells: 78
Chemistry: Lithium - Ion
Connectors: xt60 + 2 pin for battery meter
Does not come with a charger
Price: $195
Manufacturer: SCUD
Weight: 8.7lbs
Voltage: 48v
Capacity: 19.2aH
Amount of cells: 78
