Johnjayjrv
- Mar 31, 2021
- 57
Need some battery advice. I am looking to replace my 2 6v Lead Acid batteries with these, https://www.batteryclearinghouse.com...2v-22-5ah-pack in parallel using this https://jag35.com/products/dc-pcb-po...32028533457011. Jehu has a video showing the batteries pushing 80 Amps through that PCB board. I know I'll need to change my WFCO charger but I have a Victron MPPT that I will connect to and use a 120w panel to top it off until I get the charger swapped out. My trailer is a 26DBH-L with a 12v fridge. The batteries will be in a toolbox that I will make sure is waterproof until I can find a better solution. Does anyone see any issues with this? I honestly don't see anything pulling more than 80 Amps and that's my only concern.
