tpenfield
Greetings . . .
I have 2 new ( 6 months old) LiTime 12.8v 100Ah (Trolling Motor 'TM') batteries w/ the LTCP feature in my boat. These 2 batteries are in parallel. (see my thread in the marine section for the design/installation details). There are also 2 SLA banks, 1 for each engine in the boat.
The boat has been tucked away for winter for about 2 months . . . the AC chargers (ProNautic for SLA & Xantrex for LFP) are/were set in maintenance mode. I had a chance to check the boat about 1 week ago and the LFP bank is reading '0' (zero) volts while the SLA banks are at 14 volts. The temperatures had been in the range of 20-40˚ F for the prior week. My thoughts were that the LTCP had kicked in, shutting the LFP batteries off. I looked for some LiTime specs to verify and came across this . . .
I'm not sure if this is the exact spec, but if it is, then I could assume that the batteries have stopped charging, but still are discharging. If that be the case, then the batteries would discharge pretty much throughout the winter, but only resume charging during some of the warmest times.
My boat does have some keep-alive draw for various things, yet is connected to AC power for battery charging/battery maintenance (ProNautic model 1230 for the SLA batteries and Xantrex model 2012 for the LFP batteries).
I had not really examined the LTCP spec's until now, and was a bit surprised to see the temperature differences between the charging and discharging cut-offs. Knowing this, my next assumption is that the batteries continued to drain with the keep-alive loads (not much) and perhaps the low-voltage protection within the BMS has kicked in, which is less comforting. I'll have to get this sorted out, and preferably sooner than later. The boat is 90 miles away though, so my time with it is sporadic.
Any thoughts on what I am seeing? Any LiTime experts here to comment on the situation? TIA.
