So I just got my battery yesterday and I started to charge it. When I got the battery voltage was 13.08 volt. Then now after charging it for like 18 hours voltage is only 13.4 volts and my charger has stopped charging saying the battery is full. According to Victron smart shunt the highest voltage was 13.52 volts and amp was almost constant 7.75 Amp during the whole charge process except a brief period in the beginning when voltage and current was lower.
This is the charger i've been using Charger 12 volt 10amp
So is my battery bad or is it the charger that somehow cant charge my battery enough? According to charts ive seen 13.4 volts should be around 90% charge only. I'd like to charge it to 100% to test its capacity.
Edit. Voltage is now 13.38 Volt resting
