Anyone have good numbers for marine air A/C units?
These are the numbers you want. All A/C manufacturers publish them.
LRA - Locked Rotor Amps: The current you can expect under starting conditions when you apply full voltage. It occurs instantly during start up.
RLA - Rated Load Amps: The maximum current a compressor should draw under any operating conditions. Often mistakenly called running load amps which leads people to believe, incorrectly, that the compressor should always pull these amps.
FLA - Full Load Amps: Changed in 1976 to "RLA - Rated Load Amps".
Here is the label on the A/C atop my RV trailer with these specifications...
