ericfx1984
- Oct 10, 2021
- 740
I am wanting a little help to predict the results of mixing the following battery packs
1.) 4s2p, 230ah Eve cells, 200 amp BMS (about 5.9 kWh)
2.) 4s4p, 304ah Eve cells, 200 amp BMS (about 15.6 kWh)
Total would be about 21.5 kWh (the smaller battery would be about 27% of the overall capacity). Does that mean then that the smaller battery would only pull about 27% with the remaining 73% coming from the larger battery?
Let's say I had a 250 amp load(I don't, but let's imagine)... Would the big battery get around 185 amps while the little battery gets only 68 amps???
Or will it be closer and less skewed than I am imagining?
