lock out tag out for plug fuse
John Frum
Tell me your problems
Is there something like this for the old style plug fuses?
I would like to lock out and tag out a single circuit.
If there is nothing equivalant to LOTO, maybe a dummy fuse with a warning tag.
Pull fuse and make a laminated sign saying circuits without fuses are locked out. zip tie through door latch.
Can't fix stupid.....If someone puts a fuse in they are going to.
The blown fuse with tag would be "tag out"
Got a disconnect switch? Or do you just grab the fuse live with your bare hands?
If actually dealing with a dangerous situation, locking out power to the entire fusebox would work.
Since your concern is someone reconnecting the fuse while circuit is being worked on, just rig up a wire to ground the hot wire. If someone does insert a fuse, it blows and no harm done.
