tanner0042
I am upgrading a Renogy 400 watt (4 panels at 100 watts each) system. I have added Dakota lithium battery and inverter. I have also added 8 more 100 watt panels for a total of 1200 watts of panels.
Previously I have run different battery banks from lead acid to lithium with the 400 watt Renogy system. I just did not have the battery capacity I wanted with either of these battery chemistries. So this is the new upgrade.
The Dakota Lithium system can take an an MTTP photovoltaic input range of 120-250Vdc. My Renogy panels are 12 volt 100 watt panels. Here is the question I am looking for advice on. These 12 volt panels have an open circuit voltage rating of about 18 volts. When I put a volt meter on them (not under load) they all read over 20 volts, sometimes almost 22 volts. If I run all 12 panels in series, I have 12 volts * 12 panels for 144 volts, that's above the system 120Vdc input and well below the max of 250Vdc input. If I use the nominal voltage for my calculations of 18 volts * 12 panels for 216 volts, I am again well above the 120Vdc minimum for the system and comfortably below the 250Vdc max. But if I use my volt meter readings, let's just go on the high average and say 22 volts per panel * 12 panels for 264 volts, which is above the system max of 250 Vdc. But this is a meter reading on each panel under no load.
Is that with in specs for the Dakota Lithium inverter?
How would you recommend I configure my solar panels for the most efficient operation and set up? All 12 in series some configuration of pairing panels in parallels and in series?
A little more information. All panels are completely vertical. The ice house is always point due south so the panels are perfectly aligned to the south. The system is primarily used in Jan and Feb and the sun angle I calculated for that time of year is somewhere area 20-30 degrees for best panel angle. However, I am using this on a frozen lake and the amount of light reflecting off of the snow and ice is insane. I believe it more then makes up for running the panels vertically instead of at what the measured best angle should be. The benefits of vertical installation for me are ease of hanging panels on the side of the ice house and snow will not accumulate on a vertical panel.
Dakota Lithium Home Backup Power & Solar Energy Storage System, 5-20 KWh Battery, 3,000W Inverter
(https://dakotalithium.com/product/d...tery-3000-watt-inverter/?attribute_pa_ah=5kwh)Previously I have run different battery banks from lead acid to lithium with the 400 watt Renogy system. I just did not have the battery capacity I wanted with either of these battery chemistries. So this is the new upgrade.
