Roswell Bob
I ordered 16 of the Lishen LIFePO4 272/280 Ah cells to replace my Sears Die Hard units that I have 5 years on. Seems there is some kind of cluster-F**K going on behind the scene delaying shipments. If I don't get good news on LiFePO4 units I will go another round with the lead acid units.
I was interested in the Trojan T105 units, but thought the Crown AGM 6CRV220 might be a better choice.
I keep them in my basement so no gassing and no maintenence are very appealing. I have a bunker in my basement with 12" thick walls and a 300 pound steel door. Temperature wanders from 65F to 75F so good there.
I use about 6kWh/day, and that is mostly when sun is shining so cycles will not be very deep.
Am I on right track with the Crown AGM? Must I limit charging current to 13% of 20 hour rate?
Thank you.
Thank you.
