Prof Landsgrave
I have a portable camping 200 watt solar system that I set up and tear down on a weekly basis. I'm looking to improve the system by adding a circuit breaker that I can use as a disconnect switch between the MPPT SCC and the solar panels. All my connections are mc4. Because it's a camping set up, I'd like the circuit breaker to be as compact as possible. Unfortunately, the smallest breaker I've found is still surprisingly large, at 2" x 2" x 4". I was hoping to find something much smaller, like 1" x 1" x 4" that would have mc4 lines for connection. After an hour of searching on Amazon and the web in general, I'm not having any luck.
I was considering using 2 inline circuit breakers, but the terminal connections on those things look terrible (it's just screwed into the wire) compared to a much more robust mc4 connection.
Can anyone recommend a compact circuit breaker (~30 amps 10 AWG) with a good terminal connection?
And one other question. For a solar power line, would it be sufficient to put a breaker / switch on just the positive line, or should the breaker always be on both the positive and negative lines? (I'm guessing the latter is better.)
Thanks,
Bill
Thanks,
Bill
