Carolina Jim
- Jan 16, 2021
- 26
Hi jim here i want to build a 12v 100ah 4s lithium ion battery. but need help picking a bms any help would be great. Thanks. Jim
Daly makes a 2V 60A BMS w/30A charging, but it has no monitoring features, and it can't be programmed. I paid about $22 on Amazon.
Dayum! you put them out of biz
I just ordered 100ah cells.
I'm looking at 45amps tops. On average considerably less. I thought I would look at the 60amp BMS range for plenty of head room.
This will be my 1st battery build so im not shure how much i need ???Welcome to the forum. How much current do you need?
This is the most important factor in determining BMS size/rating so its pretty important you get some idea what your max current draw will be.This will be my 1st battery build so im not shure how much i need ???
Ok that's what i thought. my end goal will be 3 of these battreys. my needs at the cabin are small led lights water pump 12v fan and such. how do you know you are getting a good quality bms at a good price .amazon doesent have much that i have found. Thanks for helping me i know im lost with this stiff but love to learn but at 53 i don't retain much. Thanks. JimThis is the most important factor in determining BMS size/rating so its pretty important you get some idea what your max current draw will be.
This is the somewhat tedious but important step of thinking through and adding up all the loads (power consumers) that might run at one time.
An 'energy audit' will help answer this, and other important questions about your system.
Alternatively, you can just buy a BMS that is significantly larger than you think you might need, or can carry more current than your battery is rated for if you want to sidestep the energy audit. But you at least want to have an idea what your major consumers will draw.
You have a 100Ah battery, if its rated for 1C, you should never go above 100A continuous, and ideally you should try to stay below half that most of the time. If you buy a ~120-150A BMS you can be relatively sure it will not be the bottleneck
I have another question. can i buy a smart bms and use a 12s and connect to 3 separate 4s battery cells???? Thanks jimHi jim here i want to build a 12v 100ah 4s lithium ion battery. but need help picking a bms any help would be great. Thanks. Jim
No. the __s refers to # of cells in series. 4S = 12V, 8S = 24V, 12S = 36VI have another question. can i buy a smart bms and use a 12s and connect to 3 separate 4s battery cells????
Its a fraught market, not quite as bad as the raw cell market, but competitive. Stick with what others have used and had good experiences with. Learn about the basic purpose and function of a BMS (there are a wide range of features, the core essential featureset is cell level monitoring, balancing, and high and low voltage disconnect, low temperature disconnect is also important).Ok that's what i thought. my end goal will be 3 of these battreys. my needs at the cabin are small led lights water pump 12v fan and such. how do you know you are getting a good quality bms at a good price
