brandnewb
Going for serious. starting as newb
My current breaker panel is in disarray.
It is the result of hastily adding new components over time during house construction without reevaluating the layout before each new addition.
So basically prototyping but then without starting from scratch every once in a while.
I have opted to not yet let a professional clean it up because I first need to understand what is going on there so I can make sure that the cleaned up version will also do what I need it do. Yes believe it or not the current version does actually do what I wanted from it when it was being created.
Also, and please do not see this in a wrong way but I would rather learn from an expert now while I can and learn to be able to do it my self
This corona pandemic lock down waked me up regarding the need for self reliance. I am not trying to be stingy and deprive anyone from a well deserved pay check for good and honest work rendered. It's just that history has proven us that sometimes there is no help to be found and you are on your own.
Is there anyone, close by would be better, willing to help out on a commercial basis and get things in order there. It will be planning, theory, reverse engineering, documenting and also of course actual building a cleaned up version of the breaker panel.
Please PM me and we can talk your hourly price.
Cheap chinese horizontal wind turbine, an in depth exploration.
It's not an Alternater yet because there is no Diode pack attached to it. It is a Motor/generator. The spinning thing has magnets on it which makes up the thing called an Armature. The coil thing is called a Stator. The moving magnets cause current and voltage to flow in the coils. The faster...
diysolarforum.com
