All of the larger Anderson style connectors I've seen installed on panels have been screwed in through the hole in the center of the connector itself. They cut a rectangular hole that's slightly larger than the Anderson connector, that was butted up against a wall. The connector was then bolted to the wall, and you can plug in a wire easily.
You can see in the picture in the link below where the connector is just a rectangular hole with a flat bracket behind it.
Feb 15, 2019 - Find many great new & used options and get the best deals for Genuine Anderson 50A Connector To 12V Cigarette Lighter Hella Merit Plug Adapter at the best online prices at eBay!
www.pinterest.com.au
II think this might be the specific product that you're looking for if you're not opting for a do-it-yourself option.
175a Mounting Kit. 175a Mounting Kit, 2 Plugs. Mounting Kit for 175 amp Anderson Plugs, suits all types of 175 amp plugs. Anderson Plug Mounting Kit Options. A locking tap that goes on the plug being inserted prevents the plug from accidental removal or rattling out.
www.ebay.com
