Need some advice on an upgrade. I have a 10 year old 24 volt off-grid system that I'd like to upgrade. I'm debating on replacing the 450 AH FLA battery bank with 2 24 volt 280 AH Lifepo4 batteries. I have a 1500 watt array of 6 panels, a Magnum 4000 watt inverter and a Midnite Solar Classic 150 charge controller.
OR
Do I replace everything? looking at an EG4 XP6000 and the EG4 48volt 280AH wall battery. So many questions, I live in a cold climate so I'd need to build something insulated for the Lifepo4 battery. The start up voltage of the EG4 would require all 6 of my current panels to be wired in series, currently 3 strings into a combiner. The idle current of the Magnum inverter is 25 watts, half of the EG4.
So is it worth replacing the 10 year old 24 volt equipment and going to 48 volts with my not so big off-grid system? Or just upgrade the batteries on the 24 volt system to Lifepo4? And option 3, just put in new FLA batteries and not have to worry about the cold?
This is a cabin that's used 3 seasons and fulltime during the summer months. I do make weekend visits during the winter, so low power usage during the coldest time of year.
Thanks in advance
OR
Thanks in advance
