I have 6x100ah Vatrer 48v batteries with M8 5/16" terminals.
https://www.vatrerpower.com/products/vatrer-48v-100ah-server-rack-lifepo4-lithium-solar-battery
I currently have them set up daisy chained with one inverter/charge controller on either end. I recently learned that the energy would be better distributed if I had a bus bar system with equal length conductors. I'm having difficulty finding a good bus bar that will have 8+ studs and accommodate 1/0 lugs sized 5/16" . For example this has the count of studs I want but they're not 5/16" size:
Efficiently distribute high current and connect batteries or DC equipment with the Victron 600A Bus Bar. Durable, reliable, and versatile.
www.currentconnected.com
Or this has 5/16" lugs but only 6p:
Maximize power distribution with the Victron Bus Bar 250A 6P. Stainless steel terminals, tin-plated copper nuts, and 70 VDC compatibility.
Forgive me as I'm new to this but are any of these solutions proper:
1. Get 2x6p 5/16" bus bar and bridge them with a short 1/0 conductor. 4 bus bars total, but 2 for pos and 2 for neg.
2. Double up the bus bar studs with 2 battery leads each so 3 of the 6 studs will have 2 leads, and then 2 more studs for the two inverter/charger leads.
3. Downgrade to a wire size that accommodates 1/4 lugs (but keeping 5/16 on the battery end) and using one of these:
Efficiently distribute current and connect batteries or DC equipment with Victron 150A Bus Bars. Durable, reliable, and versatile enough for all your needs!
I wouldn't be pulling any more than 150A of current so this is the ideal amperage rating but the only examples I've seen of this bus bar in use was with much thinner gauge wire.
There are many other choices on Amazon but I'm trying to follow Will's advice to only use reputable products.
