Cabin has an accessible attic, and interior walls are paneling (easy access for running conduit). Foundation is pad and post. Lots of room underneath. Shed is about 10’ from cabin. Underground conduit (or other?)
I’m thinking:
1. PV wire into soladeck box > thwn into metal conduit through attic, through interior wall, floor, run under cabin and then underground to shed.
2. Pv wire into combiner box > metal conduit to soladeck box located near roof edge > metal conduit through soffit, along exterior cabin wall, then underground to shed. This way would be easier and faster.
I could also run conduit to the gable end, either on the roof, or through the attic then along the outside wall.
Are there any other ways to do this that I haven’t thought of? I watched a you tube video and the guy used some kind of rubberized wire with that metal Armour stuff along a wall.
Not sure if I should use metal the entire run, or metal where required, and then transition to pvc underground?
I’m thinking:
