scottsmithline
- Aug 26, 2021
- 7
Hello, I am building a simple small backyard solar system to power a small fridge, one or two small fountain pumps and some led lighting. I am starting the system as follows:
295 watt REC solar panel
100 Ah LiFePO
Victron Smart Solar charge controller (100/30 sized for expansion)
Victron Smart Shunt
Blue Sea fuse block
wiring, fuses, breakers etc. as necessary
I will be including my children in this build and one of the things that seems to interest them is being able to see real time indications of power usage. I am therefore planning to install a couple simple power meters after the fuse block to display the real time power consumption of the the various loads. Given the additional complexity and clutter on the power board, I was hoping to install only 2 meters and then be able to switch which loads are running through the meters at any given time.
Is there a simple way to wire this up? Any suggestions appreciated.
Thanks!
100 Ah LiFePO
Victron Smart Shunt
Blue Sea fuse block
Thanks!
