Currently on order:
2 x F3800 Anker Solix
2 x BP3800 batter pack for F3800 Anker Solix
1 x Smart panel from Anker for automated transfer
Current setup:
200amp panel that powers the home
125amp sub-panel from the main panel that powers the outdoor kitchen/pool hardware (heaters , pump etc)
Current Plan:
Get the 2x F3800 setup with the main 200amp panel via a subpanel for 50amp for important circuits from the main home for emergency backup.
Problem (This is what i'm looking suggestions for):
One of the main reason to buy this stuff was that incase we're not home and temps drop below freezing and we loose power, I want to make sure that the pool/spa pumps (jandy VSP - require ~300w) running to ensure pool/spa plumbing doesn't freeze.
However I'm not able to figure out how this setup would work, since the pool pumps are powered off the 125amp subpanel that's on the other side of the home.
Any suggestions/recommendations are more than welcome.
My main goal out of this setup is to essentially run fridge / freeze / few home circuits for wifi etc AND pool pumps to prevent freezing of plumbing.
Eventually will setup some Rigid Solar panels to connect to the F3800 to charge via solar as well.
More than happy to answer any questions/provide more information.
Current setup:
Current Plan:
