Hi All,
Fairly new to Soloar and lithium batteries and looking for some BMS suggestions.
I currently have 32 Eve 304ah 3.2v Lifepo4 cells. This is for a marine application. The system is a 12v system. I currently have these configured in a 4P4S2P configuration to give me two large 12 batteries, each battery at 12.8v 1216ah. Total would be 2432ah 12.8v. If I am doing my math correctly.
I do have a REC-BMS in a Master / Slave configuration. So this would work out to 16 cells per slave with a master providing oversight for both slaves.
I continue to have issues with this REC-BMS system with the whole system rebooting frequently. I am beginning to question first the BMS and wondering if there is a better BMS solution that can handle this configuration as well as integrate into my Victron electrons. I am also beginning to wonder if there is a better battery configuration that would give me as much 12v capacity as possible but more manageable with a BMS system that will be more stable and provide better visibility and metrics.
Does anyone have thoughts on this.
Thank you for your thoughts.
