This is what I used on my Pergola build.
I have no connection with this product other than I spent my own money to buy it and I am very happy with the result.
They have a kit for 4 panels and a kit for 8 panels. The 4 panels is for under 300 watt size though. My 400 watt panels would not fit 4 on the 4 panel kit. I bought one of each (4 and 8 panel kits) and had enough hardware to mount my 10 x 400 watt panels with some rail and clamps left over. I did use all of the L feet though. The price is not bad when you figure in all the hardware included. The "88 inch" rails are almost 89 inches. But keep in mind the splice uses the same slot as the L feet and the panel clamps. So you need to plan out where the feet, panel clamps, and splices will fall to make sure you don't have interference. I spliced 3 rails end to end, but then cut 30 inches off one end and 14 inches off the other end. That moved the splices so the 42 inch wide panels all cleared and I have a few inches of extra rail out each end as well.
If you need a little more than the 4 panel kit, the 8 panel kit is a much better deal. Not only do you get double the rail and panel clamps, you also get 3 times the splices for less than twice the cost.
Not sure I would trust the rail as a complete purlin replacement. They are pretty rigid, but once they do bend, they will lose their strength fast, unlike wood. I have a wood cross bar about every 4 feet to support the rails. These aluminum extruded rails are not as strong as unistrut or super strut, but they are much lighter and all the included hardware is excellent stainless steel and aluminum. It even came with wire clips and grounding lugs.
This was while I was putting them up. The adjustable height panel clamps are a loose fit. I wrapped electrical tape arounf them so the parts would not fall apart while putting the panels on. Once tightened down, the tape serves no purpose. I am sure the weather will get rid of it fairly quick here.
