I disagree. Bulk is everything the controller can give until it hits the absorption setting i.e. 14.8 volts, after which constant voltage is held, allowing the battery to top off. Once the timed or minimum current setting is met in Absorb stage the controller transitions to float, holding the voltage at 13.6 for example. Then the sun sets and batteries will settle down to 12.8 or so (fully charged resting voltage)What were the default settings? That will tell you which is which. They were probably set to Lead Acid. Bulk is always highest. It should be around 14.3 to 14.6, regardless of chemistry. Absorption is always lower and is going to be somewhere between 13.4 and 13.8. Float is what is left. Look at the numbers and then translate the terminology to whatever you like.
Yes that is likely the scenario. Most chargers and charge controllers do not have an adjustment for current.I have only two available (relevant) settings, they being Constant Voltage, and Boost Voltage (timed)
I think that the setting called "Constant Voltage" on my charger, is where I can define the voltage reached during the constant current stage of charging, at which point the charger goes to stage 2 which is the constant voltage stage (timed) but they are calling it "BOOST"
Do you mean less Amphours?. My fixed current chargers push the same current regardless of the voltage setting. The current remains the same throughout that stage. That is why it is known as Constant Current.Yes
A lower voltage will push less amperage
Yes Constant Voltage (often called Absorb) can be a timed stage or one the shuts off at a ending Amps setting. That contradicts my earlier statement but the key term for those that have that setting is “ending Amps“ or something similar. Minimum Current is another term that is used.Am I correct in thinking that the only stage that should be timed is constant voltage?
This is referring to the CV stage. (Absorption)Do you mean less Amphours?. My fixed current chargers push the same current regardless of the voltage setting. The current remains the same throughout that stage. That is why it is known as Constant Current.
Yes, but for the benefit of uninformed readers, the battery is not self requlating. It will take a lot of Amps if you raise the voltage of the power supply or charger up to the limit of the charger..Current is determined by the battery.
YupYes, but for the benefit of uninformed readers, the battery is not self requlating. It will take a lot of Amps if you raise the voltage of the power supply or charger up to the limit of the charger..
I've never seen a regulating device that doesn't have a bulk setting. The bulk setting limits the voltage that the current will be delivered at. If you look at any battery manufacturer's literature, they will specify what voltage to set your bulk value to and that is what it will charge at until the absorption stage is reached.I disagree. Bulk is everything the controller can give until it hits the absorption setting i.e. 14.8 volts, after which constant voltage is held, allowing the battery to top off. Once the timed or minimum current setting is met in Absorb stage the controller transitions to float, holding the voltage at 13.6 for example. Then the sun sets and batteries will settle down to 12.8 or so (fully charged resting voltage)
Well then you either haven't seen very many controllers or need to look at the the instructions again.I've never seen a regulating device that doesn't have a bulk setting. The bulk setting limits the voltage that the current will be delivered at. If you look at any battery manufacturer's literature, they will specify what voltage to set your bulk value to and that is what it will charge at until the absorption stage is reached.
This thread, from the beginning , is talking about settings. As far as I can tell my comments are pertaining to the topic at hand. Yours OTOH contain little swipes at my comments. You really need to be better informed when giving out advice like when you said, for example "Absorption is always lower and is going to be somewhere between 13.4 and 13.8." This sounds like you know very little about battery charging and charge settings. You really have no business giving out advice till you have a better understanding of the topic at hand.Okay, I said "regulating device", I was not specifically talking about solar controllers. I haven't, until now, seen that controller. Thanks, that's interesting, but doesn't change my advice to the OP. He can still look and will likely see what I was pointing out.
Aboard my boat, I have Victron solar controllers and a older PWM controller, a Xantrex TC2 shore power charger that replaced an older one of a different brand, and a Balmar regulator for my alternator. All have bulk, absorb, and float settings which are set to Trojan's specifications for each stage.
So what was your advice to the OP, or were you just browsing the thread looking for an opportunity to take it off the rails? lol
Your comments in this thread are limited to one response to me. Nothing whatsoever to the OP. Maybe you should try helping him instead of picking fights with other commenters. LOLThis thread, from the beginning , is talking about settings. As far as I can tell my comments are pertaining to the topic at hand. Yours OTOH contain little swipes at my comments. You really need to be better informed when giving out advice like when you said, for example "Absorption is always lower and is going to be somewhere between 13.4 and 13.8." This sounds like you know very little about battery charging and charge settings. You really have no business giving out advice till you have a better understanding of the topic at hand.
As far as your little pot shots are concerned you seem to be the one taking the thread off the rails.
