EvanVanVan
- Nov 29, 2022
- 2
As the topic states, I'm looking to power an IR Illuminator (the biggest for instance, https://www.amazon.com/CMVision-IR130-198-Outdoor-300-400ft-Illuminator/dp/B004F9LF7E) for ~12 hours at night. I was going to order a $15 "Bionic Spotlight" I had seen an infomercial for an try to swap out the LEDs for IR LEDs, before I saw Amazon had other small solar dusk-till-dawn options. For instance, https://www.amazon.com/gp/product/B07S5HK3T9/. The battery appears to be part of the solar panel which is good, I'm assuming I could modify the cord/plug and just use an external illuminator. But looking at the specs it doesn't look like it would really be enough power output for the large illuminator I linked, it might work on some smaller ones. At these price points though I'm also wondering how long they could really last or what the quality would be.
I know nothing about this but figured I'd look into getting my own solar panel, battery, controller, etc. and at least see what it would cost (Or if there are any decent quality all-in-one solar/battery solutions?). I was assuming I would get separate solar lights for the 2-3 IR illuminators I need but if going the DIY route I can run wire between all of them if it makes more sense for the small loads with a large enough battery. The distances are not right next to each other, but within a couple hundred feet. FYI, this will be used outside in Vermont, I read one Amazon review warning against charging the battery in freezing temperatures.
Thank you
Thank you
