SolarMinerPH
- Sep 21, 2021
- 17
What would be the pros and cons of having lots of paralleled 32650s to get 102ah vs 1 100ah prismatic cell?
I am planning on building a 48v 100ah battery.
I made some calculations and I will need 272 pieces of 32650s to build a 48v 100ah battery vs just 16 pieces of prismatic cells.
Pros of the prismatic is it is much simpler and easier to build.
Cons of the prismatic is it is more expensive
Pros of the cylindrical cells is It is $220 cheaper
Cons needs more work to build.
To other experienced users out there can you please add more pros or cons like why I shouldn't build my battery out of cylindrical cells and vice versa. I already googled and I did not find much info about this one.
I planned on building using cylindrical cells before that is why I bought a spot welder a few years ago when 18650s is still the rage but then bigger prismatic cells are now widely available which makes it so much easier to build a battery. But I can potentially save $440 usd if I went with the cylindrical 200ah setup. Is the $440 worth spending on bigger prismatic cells?
