SparkyGage
- Oct 3, 2019
- 103
I've mainly been a lurker, but thought I would share my project - powering my sailboat on the weekends and my shed during the week. I'll put the back story at the bottom. I'll update this first post as I learn more.
Current setup as of Sept 1, '23: (I'll keep this at the top and update as I make changes)
Total relevant spend (sans boat): $2028
Boat: 23' Spirit Sailboat
Transom mounted trolling motor: Newport 24V 86lb thrust ($340) (maximum draw 48A) (March)
Battery: 24V iPowerQueen 100Ah ($700) (March)
Battery Charger Solar: 30A MPPT 12/24v ($95)(March)
Battery Charger AC: 12V-20A/24V-10A ($60)(April)
Battery: 12V Interstate deep-cycle (came with boat)
Quick disconnects 600A forklift style ($33+20)(July)
10' 6ga cable ($40)(July)
1200wt 24v inverter (Returned)
EcoFlow River 2 Pro ($540) (Sept)
Use case:
- I haul the battery between house and boat. I use quick connects much like those found on forklifts. The 24V is lighter than the 12V
- Boat on fresh water lake in Arkansas to move in & out of marina and around coves 3-6 days a month / 9-10 months a year.
- Shed in Arkansas to power lights, hand tools and low amp motors like a drill or bench grinder. 1-2 hours a week
- Operational Temps: Lake 40F-100F / Shed 15F-110F (but more like 40-100 when in use)
- Emergency auxiliary power. Will supplement and eventually replace gasoline generator.
Boat Results after 9 runs: So far so good and summer is over.
Run 9 - Cooling off. Approx 4 miles on battery. Low 60s F. Strong headwinds leaving marina.
Run 8 - Over Night Trip: Approx 14 miles on battery over 24hr period. 70-90F. Battery remained at ambient temps.
NOTE: (Sept 25)Biggest test of the system so far. Insufficient wind for most of the trip and had to rely on battery more than planned.
Run 7 - Approx 2hr on trolling motor on level 2-4. 5.7 miles on battery. 80-90F. Battery remained at ambient temps.
NOTE: From what I can see from monitoring my charger, I'm using just shy of 60% of the battery or 50-60Ah of juice per trip.
Run 6 - Approx 2hr on trolling motor on level 2-4. 5.5 miles on battery. 80-90F. Battery remained at ambient temps.
NOTE: Battery Voltage on charger after return shows 26.3V which is approx 50%. For details see post dated Sept 12 below.
NOTE: After charging, my charger indicated that it had put 58Ah+ into it so it's possible it was closer to 60% used on this trip.
Run 5 - Approx 1hr on trolling motor on level 2-4. 3 miles on battery. 85-95F. Battery remained at ambient temps.
Run 4 - Approx 1-1.5 hr on trolling motor on level 2-4. 4 miles on battery. 95-103F. Battery remained at ambient temps.
NOTE: Head wind returning to the marina. Used 3/5-4/5 speed most of way back. Total trip 11 miles.
Run 3 - Approx 1.5hr on trolling motor on level 2-3. 5 miles round trip on battery 85-95F. Battery remained at ambient temps.
NOTE: Head wind returning to the marina. Used 3/5 speed most of the way back. Total trip 7.5 miles.
Run 2 - Approx 1.5hr on trolling motor on level 1&2 5 miles round trip on battery 80F. Battery remained at ambient temps.
NOTE: Light side breeze. Was only under sail 30 minutes of the trip. Total trip 6 miles.
Run 1 - Approx .75hr on trolling motor on level 1 moving around marina. 75F
Observations: Battery meter on motor is useless. Shows 30% charge all the time. Est level 2 is 3mph
Current estimated run time 5hrs on level 2. (will update as I am better able to measure usage)
Planned Expansion and Changes:
Solar panels on shed to charge/maintain the battery (charger for solar shed already purchased with battery),
(Was 2k PSW inverter for shed - went with 1200wt instead after measuring loads and finding a 1200 on sale),
Portable solar generator mainly for use at home but possibly to take to boat,
24v to 12v DC/DC converter on boat when I am comfortable with battery's capacity for overnight trips.
Convert boat to LED lighting.
Solar fan to keep boat cabin aired out when not in use.
Solar panel(s) for boat for extended stays.
Back story:
Bought a 23' sailboat for my favorite lake which is a 30min drive from home/office. I keep on the lake with the goal of being able to be out if the marina 45minutes after I leave the office/house. It's just big enough I can spend a night or two on it. I don't want to use the 6hp outboard it came with because I want my wife to be able to control the boat without having to deal with a traditional outboard in an emergency (MAN OVERBOARD!) Trying to keep this low budget because I'm CHEAP and I am also a Geek so everything is a project to obsess over. Didn't want to spend $$$$ on a system that just sat idle at the boat 90% of the time. And since I haven't mastered the art of being in two places at once, I figured my boat setup could also power my shed when I need it - mainly lights but the tools that I am using a 100' extension cord with as well. Add some solar panels and now my setup is even more efficient. Also a good learning exercise before adding solar at home.
If asked a question, I'll try my best to answer.
(all worthwhile information in this post was blatantly stolen from other posts on this forum or from Will directly)
Use case:
Back story:
