chillybags
I built my 36v 12s LFP battery and on first use had a short which melted the BMS balancing wires and burnt some foam i was using as a spacer. There only appeared to be minor cosmetic damaged to the top of the prismatic cells.
I have learnt form my mistake and I have rebuilt the battery and replaced all the melted BMS wires and secured them appropriately to prevent another short.
Everything seems to be working ok on that front. Photos below - I have replaced the two red cables running from pack + to the fuse with 50mm welding cable on either side of the fuse.
Got the battery installed in my golf cart and on startup when there is a decent current draw (up to 200a) the JK bms shuts down on UVPR on some of the cells (got a screenshot below), with some cells dropping very low. As soon as the load to the BMS is cut voltage comes back up to 3.3v almost instantly. The cells have been charged up to 3.65v, i havent done a top balance due to JK BMS active balancing. When fully charged when the first cell hits 3.65v most cells are at 3.6-3.65 but theres two cells sitting at about 3.58 - i know not ideal at this stage but didnt think it would make such a big problem right this second.
I have Grade A EVE 105a cells (purchased from amy wan from luyuan) that have a 1C rating up to 3C pulse, the JK BMS can handle 200a up to 350a pulse. I thought these specs should be ok for my needs but it seems maybe the cart is pulling way more current than the setup can handle?
If i am very careful and start the golf cart at a very slow pace and draw under 100a then once it is going it stays going.
