R ramiws New Member Joined Aug 1, 2020 Messages 91 May 30, 2021 #1 I got working once and now with another one of same unit xtra 30A it is not. What can I check or do? if you can see picture attached. it says -6 degrees and the batt light is still green and charging from panels. Attachments 20210530_120010.jpg 105.8 KB · Views: 4
pollenface Solar Addict Joined Nov 14, 2020 Messages 1,843 Location Perth, Australia May 30, 2021 #2 Add a temp controlled relay to connect/disconnect your pv at a desired temp. If that's what you want to do? What is the temperature compensation set to on the controller and what is your battery chemistry? Last edited: May 30, 2021
Symbioquine Solar Enthusiast Joined Jul 6, 2021 Messages 422 Jul 14, 2021 #3 If the guts are similar to the Epever Tracer####AN hardware, it probably has a low temperature cutoff that can be enabled. See my post at https://diysolarforum.com/threads/i...apable-of-low-temp-shut-off.22931/post-301020
