I've got a new travel trailer that I'm replacing the Lead Acid Battery with the latest Moseworth 12V 120Ah LifePro4 battery. I'm also swapping out the current trailer battery charger to a Progressive Dynamics PD9160ALV 12V Lithium Ion Battery Converter/Charger. My concern is that I'm not getting consistent responses from the seller whether the battery has low temperature disconnect. For my solar panels I can simply disconnect them when below zero, but I'm worried that my PD9160AL may try and charge the battery when connected to shore power and the outside temperature is below zero. Would a Victron Smartshunt 500A have the capability to disconnect the charge from the 9160 to the battery if I set up some alarm or parameters via the bluetooth app using its' temperature sensor? If yes, can I still use and discharge the battery the other direction? Is there another more elegant or cheaper solution other than moving the battery inside the trailer?
