I have a simple 12V system with a 100W PV and two 100Ah AGM batteries.
I am under the impression that I shouldn't ever let the batteries drop below 12.2 volts - 50%.
I see that the charge controller (Windy Nation P30L) was set to shutdown at 10.7V. If it hits that, wouldn't it be too late?
Shouldn't it be set to 12.2 or 12.3 volts?
I just bought an Epever MPPT 30A controller that I will install tonight. What settings should I change from the default? I know the battery type is one. Is an AGM considered flooded?
Thanks.
Thanks.
