fire hazard
- Jul 14, 2021
- 198
low voltage disconnect
Most of the mobile inverters lack any ability to adjust low voltage shutdown. Workarounds with a external low voltage relay tend to be hard to implement and often do not do what you want. Your best option is to buy those inverters that allow you to adjust various voltage events. These tend to be either inverter/chargers (with ATS) or AIO's.soooooo have many inverters they all disconnect around 10.5.too low,so how do i fix that
Sorry but my efforts to implement it a couple of years ago were disappointing so I instead went to an AIO. Much easier to work with.can you point me in the right direction,for a relay,seen a video where they wired a lvd to the rocker switch on the inverter
What inverter do you have? Does it have a remote switch/panel ?can you point me in the right direction,for a relay,seen a video where they wired a lvd to the rocker switch on the inverter
Provide it power from the battery. And connect the power switch wires through the relay.i want to use is a 1100w pure sinewave 12v with a wireless remote control,could it be wired to the rocker switch on the inverter,hey timeselectric,how would you wire that up.looks interesting
Yescan it be wired to the rocker switch on the inverter
sorry,could you clairify where those wirers are going i see the pic but a little confused,i see 7 wiresWhat inverter do you have? Does it have a remote switch/panel ?
If so, it's not that hard. I recently did this with a voltage sensing relay and an FCHAO 24v 1800w inverter.
I opened up the remote panel, which has a simple ON/OFF switch. Soldered two wires, one to each if the switch terminals. Then connected these wire to the relay.
Of course you need to supply power to the relay too.
I like this solution because it's a soft shutdown. Another option would be to use a contactor on the DC inputs of the inverter
But I don't like the idea of "pulling the plug" while inverter is under load.
Here are some pics:
View attachment 214743View attachment 214744
The relay used is one that has a 24v working voltage. 12v ones exist too. If you have a 48v system, you will need a DC-DC step down converter to power the relay.
Here is a link to the relay:
What's nice about it is that you can configure it with a "disconnect" voltage (say 24v for a 24v system) but also a "return" voltage (say 25v). This helps minimize frequent ON/OFF when disconnecting, because of voltage sag and resting voltage of the battery.
Yeah, I had some more things going on in that picture.sorry,could you clairify where those wirers are going i see the pic but a little confused,i see 7 wires
just ordered it from amazon 21$,thanks guys hope i dont blow it upHere is a video of Andy using one to control a balancer.
It will give you an idea of how it works. And how you set the limits.
No pre-charge problem if you use my method, by switching via the inverter on/off switch.It will be trial and error setting a low voltage disconnect under load.
Depending on your charge controller, you may be able to set up the load terminals to signal a large relay/contactor to disconnect at a desired voltage.
In one example using a 150w dc-dc charger and an Epever 4210AN, I set the disconnect value to 11.5v under load to achieve a resting voltage of 12.4v
That said, I wouldn't use this method with a >12v inverter that requires pre-charging of the capacitors, but a 1100w 12v inverter would be fine.
omg little scared at first,works like a dream.i cant thank you enough,now i am ordering 3 more,again thanks for taking the time,soooooooo easyHere is a video of Andy using one to control a balancer.
omg if you have been following this post,that little controller works great and very easy to install if i can do it anyone canSorry but my efforts to implement it a couple of years ago were disappointing so I instead went to an AIO. Much easier to work with.
