Most standalone inverters have low voltage shutdowns that are far too low for lithium batts, as low as 9V on a 12V inverter! (Giandel says 9.5+/-5)
What options are there to use low capacity cutoff signal from a shunt? Are there relays that can either cut off power to the inverter or (better) turn off with the inverter's own remote switch?
Alternatively, are there any non-AiO inverters that have adjustable cutoffs or built-in shunts?
I'm building up from a 24v milk crate system. Not sure if I should add a 2kw giandel inverter and a diy control system, or if there's a more expensive but plug and play option.
